With a yz250 pushin over 40hp, slotted mounts are a bad idea.
Not necessarily true, if you use an adjuster bolt to do the tensioning. My mount is made just like the adjustable Briggs and clone mounts, in that it sits over the frame rails, clamps from the bottom, and doesn't even have an adjuster bolt,
yet. When I raced it in the 1/8 mile at Lakeland, it was hooking so hard, it actually yanked both front tires, and didn't move the motor, or loosen the chain, so it's definitely doable.
Razor121 , have you looked at this thread:
http://www.diygokarts.com/vb/showthread.php?t=4742 , might be some stuff in there to give you some ideas,
