Chain info and experience
farmall
I've spent a bundle on sprockets for the 420 size chain. They are in much shorter supply and harder to find than the more standard size 40 chain. The size 40 chain and sprockets can be purchased almost anywhere and a lot cheaper with a very big selection available.
From what I have researched, there is only one difference between the 420 and the #40 chains. It is the width of the roller, therefore leading to the total width of the chain. The pitch is the same on both 1/2", the roller is the same diameter 5/16th's" the pin is the same 5/32", even the chain strength is very close. But the roller width is slightly different . The 420 chain roller width is 1/4" while the #40 is 5/16", the 420 being 1/16" narrower than the #40.
My question is, What will happen If I use a #40 chain on the 420 sprockets? It would be a little sloppy. Would this cause wear problem, how about chain running off the sprocket problems. Has anyone had experience with this? I'm worried that now all is done, that the chain might need replacing also.
A little back ground. The mechanical stores around the area have told me they no longer are sold the 420 chain in bulk for resale because it is classified as a motorcycle chain and the chain makers are restricting it to motorcycle outlets only. It is also an older type chain that isn't used as frequently today. I ended up having to buy 420 sprockets with my tooth pattern and have them machined to fit my applications.(exact matches were not in the books) I should have just changed over to #40 to begin with and changed out everything.(they were all available! and at about 1/4 the cost) It would have been much much cheaper! But that is hind sight now.
Thanks for any input in advance.
You can run a #40 chain on a 420 sprocket with no problems. Is is done all the time and several people on the forum will tell you so. Some might be even doing it themselves. It is a common practice
farmall
Thanks for the reply. I'll be getting a 38 link #40 chain instead of the 96 link 420 chain and throwing most of it out. The 420 chains don't come in bulk and you have to purchase the only available sizes they have already pre-cut.
rmm727
Brookville, PA
Why dont you get #41 chain. It is the same width as 420.
Edit. Looks like the roller diameter is a little smaller on #41 according to Gizmology.net. I always thought that the difference between 40 and 41 was the width. Maybe its a typo?
farmall
the #41 is an option except for the fact that the pin and roller are smaller and the side plates are thinner. It appears that it would work but in my case I need the strength. a 41 is about 1/2 the strength of a 40 from the charts I have read.
farmall
You look hard enough and have enough help, it always seem to work out. Thanks for the links.
Problem solved:thumbsup:
