Chain, Belt & Oil Questions
Can you two discuss your love lives privately, like in a PM? 😬
Looked at a Subaru EX17 manual...
Don’t ever read these manuals, they condemn and indict you over the maintenance you’re not doing. And here I am expecting fuel lines to last forever... Anyone know of a fuel line that stays flexible forever and doesn’t turn as hard as a carp?
Squiddy202
Manco Dingus
Eastern Pennsylvania
Quick question, when my kart is coasting it seems to make a noise like crying Donald Duck. I think it is coming from the cvt. Is this normal? It cropped up after I adjusted chain tension by moving the jack shaft and engine. Any thoughts? The pulleys still seem pretty dang straight. I adjusted the belt tension to the spec sheet.
Perhaps you should unadjust the chain tension. Start over, then 1 step at a time, in the correct order and l'll bet the problem becomes very obvious.
Easy for me to say! Right?
I'm not doing the work!
I can't even begin to know how many times i've had to redo something. I've spent hours making something only to find some flaw, either in theory, process, function or fit, only to throw it in the scrap and start over. Thats learning the hard way.
Take a break, rethink it and start where you started when the problems began, you'll figger it out quickly.
Probably 90% of the classics here were discarded at some point cuz the PO couldnt fix it, didn't know how, or got frustrated.
Thats all! Now git out there and give em hell!
Dont take no shyt from some little machine!
