So I made a few changes to my cart. The one that is giving me trouble is switching from a 64t to 54t sprocket. I did not think it through but when I put it on the chain is now too long. Well I got around that problem by using an idler pulley that's on my kart. Problem is this pulley has a loose fit to the kart frame. To remedy this I used the spring that was with the pulley(I do not remember how it was put on). The alignment isn't perfect though and the chain pops off after going over a certain RPM(around 3000).How would you fix this?
Also I put in a Dyno CL-1M-Improved cam in the predator. It runs fine, but now the recoil starter is very hard to use. Seems I've read some about these cams not having a compression release? Is this correct? I can live with the harder pull, but would like to improve it if possible.
