Here you go
http://www.gopowersports.com/10t-3-4-bore-max-torque-centrigugal-clutch-41/
18mm is almost equal to 3/4 inch. 3/4 inch is around 19mm, 3/4 clutch will be fine.
Is this for you pedal kart? Let's see some pics of your progress.
What.. NOOOOO that will NOT be "fine".. a mm of play is far from being acceptable...
I googled your engine it's a 3/4 shaft you'll be fine. Where did you get 18mm from?
the heck? but you know honda makes up to 6 different shafts for each and every gx model, don't you?
metric straights and imperial straight shafts, tapered, threaded, splined...
No? So what exactly have you googled then??
Now, that being said..
I'm afraid thermocouple, you have no real option left.
You can make yourself a sleeve for your shaft to fit a 3/4" clutch
which is not an off the shelf product,
you could bite the apple and buy the ONE cent clutch that is indeed out there (belt clutch I'm afraid)
https://www.lsengineers.co.uk/centrifugal-clutch-to-suit-a-18mm-shaft.html
(100++ bucks
or you could spend some money to buy the 3/4" shaft for your exact model gx120 and mount a 20 dollar clutch..
I'd say
try to make a sleeve first, 0.5mm sheet metal isn't too hard to find, cut a 60mm wide (or better a perfect match for your shaft length) 50cm long stripe and roll it as straight and tightly as possible.
allow the springback to happen,
then find the 18mm position with a caliper and cut your shaft sleeve.
keep in mind that you leave a 5mm gap between both ends for the key
(and miniscule play)
if that fails, all other options almost justify buying a new engine really.
especially if you have access to cheap chinese clones (say a predator in the US of the lifan 168 [both more or less gx200 clones for 100 locl buckaroos])
Oh, I think the 18mm keyway is narrower than the 3/4" keyway,
use a 1/4" key (for the 3/4" clutch) and file it to fit the shaft, the smaller key might allow for too much play and sheer off once you run the engine under load.
