centrifugal clutch
yeabuddy!
so ive got a belt centrifugal clutch on a robin 8.5 hp motor. its old, it was on the engine when i found it. so the problem is that, if a light weight person under 170 or so hops on, and cracks the throttle it works alright but heavier people, it doesnt seem to do much. so, where can i find the right clutch, what would the specs be, and what would be the right centrifugal clutch for all weights?
Bluethunder3320
sounds like you need to change gearing not the clutch.
there is too much load and the clutch over loads.
