Centrifugal Clutch Question
xyster
For right now I have a 3.5 hp horizontal shaft Briggs and Stratton motor. My 2 Clutch options are,
1) Bore 3/4" //# Of Teeth 12 //Chain Pitch #35
2) Bore 3/4" //# Of Teeth 10 //Chain Pitch #40/41
And with that do you know how many teeth I would want on my wheel sprocket.
Any info would be great
Thanks
Kenny_McCormic
Kartless....
Michigan Troll
I would go with #35 for a single wheel drive setup #40 is bigger and the sprocket is bigger for that tooth count. with a .5 horse get the biggest driven you can fit.
xyster
So if I went with the 12 tooth #35 clutch then how many tooth sprocket would I want on the drive tire
fluxcored
Xyster, let me know how it works for you. I'm buying similar clutch end of the month for same capacity engine and must admit knowing squat.
