CAT99 belts
redsox985
PA
I found a CAT99 TC unit for $40. It needs to be sanded a bit and cleaned up but it looks like a good value. It also needs a belt. For simple availability, will the 30 series/tav2 3/4 top belts work on the CAT99 which calls for a 5/8 top belt. I know the 5/8 top belts are available and have found them, but the wider belt seems stronger. Has anyone tried this? Could the wider belt fit even if it pushed the driver open more? The angles are the same 18 and 2.5 degree cuts.
