cwinter
Cdub
I just bought a Carter Bros 2506 and want to get it running for my kids. The cart is in fair condition, with the exception of the rear drivers side hub.
The last owner ran the cart after the bearing had failed and eroded the aluminum within the bore.
I am not certain what hub to buy to replace the damaged hub and am seeking advice. I have attached a picture of the serial number, and the parts diagram for this kart is located:
http://kartingdistributors.com/pdfs/carterpdfs/2506-3017.pdf
I think I need part:
(24) G222 Drive hub 1 3/8" bore (from the parts diagram).
How would you suggest I find the right hub?
I will post a picture of the damage to the hub this evening when I get home from work.
Thank you for your help!
Cory
Cory
