See if the vacuum operated fuel valve under the tank is working properly. Vacuum from the engine opens the valve to allow fuel flow. If you have low vacuum or a bad valve you won't get enough fuel to the engine. Use a vacuum pump to test or carefully draw vacuum with your mouth.
That's a good video
I can add a additional tip from my experience.
Before handling the lines, give them a close inspection for cracks, pinching and kinking.
I had a situation where I was getting fuel starvation.
Went through these steps but then realized that the vacuum hose was kinked
Right where the hose made a corner around the carb, it would kink nearly shut.
It would start fine and idle, but after a bit at higher rpm and it would stutter.
The hose itself was not deteriorated, just cheap China rubber.
Me being the cheap azz, I rigged up a spiral notebook wire into a tight condensed coil and positioned it on the kink, similar to what the old clothes irons used to have on the electric cords.
Been working fine ever since.
