Carburettor troubles
Cam
Nz Petrolhead
Whangarei, New Zealand
Hi guys, im having a couple of problems with my little 50cc honda melody carburettor,
Its pissing fuel out the overflow, (i have cleaned the carburettor 3 times so far, and the float needle control valve seems to be in working order!?)
And the tuning never seems consistant, (3 days, 3 different tuning runs)
I had the scooter working fine, the carburettor did not leak and so i set about the tuning, then it ran out of gas so i filled the tank up and then it started leaking, took it apart for the third time and cleaned.. etc
So i thought that i might start looking for something more workable, like a chainsaw carburettor, a walbro or something
This way it sucks its own fuel from the tank, doesnt leak and is really tunable, hi/lo and idle.
So i was asking on your experiances with little two strokes, and if i should swap out the carb for something better.
Cam
Nz Petrolhead
Id say so, ill post some pics as im not sure its ajustable but im sure if you see the pics you can tell me whether im right or not
sexyvicta
i would check the needle etc again(maybe even replace it with a new one.)
Theres a few scooter shops here in ak that have performance parts for scooters. Carbs, pipes, fancy heads n pistons etc. Ring scootling those guys will tell you what to do.
http://www.scootling.co.nz/
Cam
Nz Petrolhead
Cheers sexy, i didn't know there was any scooter specialists!
I got a mint walbro carb off a chiansaw today, the throat is 16 mil and the venturi 11, which is dayum close to the melody's throat and venturi, and both the hi and lo jet are pretty dayum close to the melody's as well, and the best thing about the whole deal -
the pcd is dayum close as well, so hell yeah a "bolt on" modification :thumbsup:
sexyvicta
i think they put like 17 or 21 mm carbs on those little 50s when they mod them. You might find that walbro is abit small/ i have no idea.
Watched some scooter racing at Mt wellington once and they were faaaaassst
You should goto scootling with heaps of money and buy a big bore kit, expansion chamber, hi comp head, fancy cdi, etc. Will be orsum :D
Cam
Nz Petrolhead
Yeah wouldnt mind but i havent got a lot of dosh to juggle :(
Gonna make a drift trike next,
the walbro is 16mil as oposed to 13 on the melodies, im just haivng problems with the fuel pump on it, i have cleaned it out so its sparkling and everything is in working order/no diaphrams broken or anything, i think it has something to do with those two holes you can see in pic 2, some sort of vaccum or pulse im guessing, hmm russ?
Cam
Nz Petrolhead
Ive had a squiz at a few little motors i have sitting, and it appears its a crank pulse feed, so i just have to make up an adapter for the carburettor, and drill and tap a feed into the crankcase where the reed valve block is located, then hopefully it will suck its own fuel and be useful.
Anyone have any suggestions or comments?
sexyvicta
i have no idea those carbs get me every time. Always muddle up the fuel lines etc when i put them back on engine
i fully reckon you should just buy a small mikuni/chinese copy. You can buy diff jets n slides etc and you should be able to find one which bolts onto your engine / scootling has brand new for like 120...secondhand must be way cheaper
Cam
Nz Petrolhead
If this doesnt work, or its too much like hard work then thats what i will be doing, for 25 bucks its probabley cheaper, i just find enjoyment in modification and customisation
Cam
Nz Petrolhead
"Now let's talk about the pulse signal for the fuel pump.
Your ENGINE will determine which pulse inlet type you need! If the engine "carb base" has a hole drilled into the crankcase you will use the STANDARD pulse port and the optional (if you have it) port must be closed off. If there's no hole drilled, you will find a fitting located somewhere on your crankcase. Use a piece of fuel line to connect the crankcase fitting to the fitting on the optional pulse inlet. There's no need to block off the standard port, as it's already blocked off by the engine mounting.
The carb must get a pulse signal from the engine! This signal "pushes and pulls" on the pump diaphragm which feeds the carb fuel."
sideways
Unfinished projects king.
Perth, Western Australia
I've found those pump thingies don't matter if you're using gravity feed, I've never bothered hoking one up and the engine's I've put those style carbs on have run fine. I figure they're just good for when you have the tank under the engine like pretty much all whipper snipper/chainsaw/leaf blower engines. I wouldn't bother if you don't need it.
It sounds like you needed to lower the float hight, there should be a little tab on the float that pushes against the needle, bend it up. You could also lap the needle into the seat or if it's a rubber needle, you can try heating it up a bit and pushing it against the seat lightly. But all that doesn't matter, go the Walbro! :D :thumbsup:
Cam
Nz Petrolhead
I guess that little bit of metal on the float must be soft or something because yes i have ajusted that , and when the float hits near the top of the float bowl it does block off the fuel, ive tested with compressed air, really weird (pos) :p
Yeah i am running the tank above the carb, but however when i hooked it up it flooded the carb and fuel rushed out the inlet, it turns out if i drill and tap that top fitting on the walbro, then drill and tap the crankcase (im going for the reed block) then hook a bit of fuel line upto it, it will pulse and pump, so im going to see if i can have a go at that today, i guess since the tank is about 4.5 litres the pressure must be too much for the carb, its quite a way up there as well.
Hows things going on your end mate?
sideways
Are you sure your float actually floats then?
Hopefully the pump will slow things down a bit then, Might be worth making a little restricter to go in the fuel line or something?
It's just been raining here, bloody sucks if your trying to work on stuff, I've just been going out in the paddock basher and cutting up the paddocks. :D I imagine thing are much the same over there? :cool:
Cam
Nz Petrolhead
Well i drlled and tapped both the carburettor and just under the reed valve block ( fortunatley it had a blank spot to drill into) and it sucks great now, just one drawback that i have to make a small fuel tank that goes just infront of the motor.
