I have screwed the needle all the way in and worked it out in 1/8 turns until the needle was completely out with no avail, I have took the new carb apart to ensure everything that was suppose to be there was there. The fuel tank is also brand new so no rust deposits blocking screens, I put fresh fuel in it, new breather and filter. I put a teaspoon of gas in it and tried to start it, I even went to the briggs website and looked up the proper way to set your air/fuel screw (which stated to start at 1 1/2 turns counter clockwise from the closed position) nothing doing. Now when I put the emission carb on there which also has no idle adjustment (carb came off a 3.5 flathead briggs that was designed to run a pump) it fires right up with carb choked and then runs fine off choke but sense I can't adjust idle I have to hold the brakes so it wont take off (Idle is set to high and can't change it). HELP!!!!
