Jccubs
Go Kart Dad
Well you guys told me to ask questions - now you may regret that decision! I bought the mint colored (yes very ugly) kart and it was far from running. The engine did run, but the throttle cable was not hooked up the right way and I don't even know if I have all the parts needed. I think I can sort out the clutch problems, the brake problems, the gas tank problems, and the kill switch problems. So here goes. I'm posting pics of what engine and carburetor I have. I purchased the linkage (you can tell it is new in the pics. Did I get the right one? The kid I bought this from had the throttle cable hooked up wrong (he had the throttle cable pulling the bent arm where there is still some yellow cable tie left in the first picture). So when you depressed the pedal the butterfly valve closed, not opened. So unless I was holding the valve closed by hand it revved up. I think what I have will fit, but still not sure where to attach the throttle cable and how this actually connects to the carb. Any and all help is definitely appreciated. I can only upload 10 pics so adding a second post to give more pics.
