mattluttrell
- Messages
- 11
- Reaction score
- 0
Hi everyone. This is my first time here.
I bought this go cart for my daughter and it was used. I've been fixing it up (tires, light bar, etc).
I noticed the front right (and rear right) wheel bearings were bad. After a fun run through the woods last night the wheel came off completely. I need to replace the hub I assume? Can you tell me where?
Here is the hub that has failed.
Here is that $50 Amazon light bar I welded onto the frame (welded the bracket). It is great. Thanks!
---------- Post added at 09:30 AM ---------- Previous post was at 09:29 AM ----------
I also intend to pull off the front suspension, clean, paint, replace that zerk and lube it.
---------- Post added at 09:46 AM ---------- Previous post was at 09:30 AM ----------
For my own documentation, I've measured the bearing, shaft and hub.
The shaft appears to be 5/8ths.
Wheel hub opening appears to be 1 13/16ths
As assumed, the bearing outer diameter appears to be 1 13/16ths
