Carb upgRade on Intek 206
JollyKarter
Texas
Good evening fellow Karters!
I have an Intek 206 on our Yerf Dog. I have been fighting carb issues since I got this motor on a Tin Lizzie kart, and sitting for 5 years didn't make it aNY better. I am thinking about just replacing it. I also plan to remove the governor and swap out the cam when I do, so I was thinking about using an Animal carb and Cam. I am trying to figure out what I need to do to use the Animal carb. I know I will probably have to get a different throttle cable, but I am trying to figure out if I need to swap anything else to bolt it to the motor.
I am also open to other options for the carb, I had picked the Animal because it is cheap and available, and I have become quite familiar with slide carbs on my atv's.
Rob
Joe-405
Enjoying New Projects
U.S.A.
Go look at the lo206 engines for junior dragsters. They have bigger carbs and are the same engine platform as yours I think.
JollyKarter
Texas
I am not necessarily looking for the upgrade portion of the carb swap...but I am thinking that I will need something different because I am not sure how I would have a properly working throttle otherwise. The carb on the motor has a funky throttle blade setup that would make hooking up difficult, unless there is something I am missing.
Rob
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I have an intek 206. Governor removed
I relocated the gas tank. I copied the funky throttle arm onto flat steel and cut out my own. I used a coat hangar for the carb hook up and attached the throttle cable to my DIY throttle arm.
See pics.
