Carb issues Briggs
checks618
Norristown PA
I just got my Manco Dingo 388-05 running. It's a Briggs model 190432 type 6035 01 8hp. When trying to set up the carb i preset the idle air mixture and the main to 1 1/2 turns out. Starts, then i dial in the idle air misture screw to a decent idle. When i pull throttle it bogs, but when i run the main screw in even with throttle relaxed the kart revs up like crazy. i cant seem to find where it should be. Am i missing something? what is the normal position for the choke lever when the engine is warmed up?
Staff Murderator
Choke should allow complete airflow; that is, it should be open when the engine is warmed up. It's only need when the engine is cold, to assist starting. It's basically an enrichener.
You need to make minor, minor adjustments when you're tuning the carburetor. Move the adjustments screws a tiny fraction, test engine, then repeat.
Sounds like you're running a bit too lean. Too rich and you'd be making a bit of smoke.
It's kind of difficult to decipher what you're trying to express.
checks618
Norristown PA
thanks, this is one of those moments i feel like an idiot. Last night was one of those times i needed to slow down and think about what is going on. i had the choke completely backwards. not physically but mentally haha. thank you for the reset. the flames coming out of the exhaust make sense now.
Staff Murderator
Kudos to you and your reasoning skills. You seem like an analytical person. You rare breed, you. :D
checks618
Norristown PA
Turns out i would never of got it right. I was still struggling with the tune, so I pulled the carb open. The idle mixture screw was broke off in its seat... the carb was one of those after market cheapies. Have a briggs carb on the way. Guess somebody didn't listen to the finger tight memo
pRoFiT
Can't buy it?, build it!
California
haha, always good to take the carb all the way apart clean it and put back together first. Some old bad gas and everything gets clogged up.
Guess we wait for your new carb now.
My last carb issue was the idle jet was clogged. that took a couple days to realize there was a idle jet.. :)
