Jim turner
- Messages
- 7
- Reaction score
- 0
Having problem with pz19 on 4hp b&s. OK for two laps then quits and won't restart even with new plug. Plug black but not wet. Rich?
Help! Thanks in advance.
Really? I ain't buying it, not to be contrary, but the symptoms are against that. The dry black plug after 2 laps does indeed indicate running rich, whether during a hard run, or more often by putt-putting around (running one of the so-called racing plugs) before the starting gun. It's the failure to restart that cries out against an empty float bowl. If it ran out of fuel during a hard run, then it should be ready to go again by the time you start trying to crank it again.Carb bowl is not refilling and it's running out of gas.
