CincyKarter
Hey All:
I have a Predator 212 Honda clone on my son's kart. It's been sitting since the fall of last year when he got a flat. We just got new tires and tubes installed last weekend, topped off the fuel and fired her up. Runs great at WOT, but it won't idle. Starts on the first pull with choke on, flip off the choke and if you don't give it a little gas at the same time it stalls. We ran it up and down the road for 5 or 10 minutes to see if we could "blow out the cobwebs" but it still won't idle.
I dropped the bowl, and pulled out the jet and tube. They were a tad bit "green" - I assume from E10 fuel they use in Ohio, and the float had some flakes of ethanol gunk on it, but I didn't see anything that was clogged up. I pulled the plastic plug out from under the throttle stop screw and made sure that was clean.
What else am I missing? We re-assembled and it's still doing the same thing. Should I hit it with some carb/choke cleaner? Will that stuff damage the little carb on these engines?
Thanks,
-- Mike
Thanks,
-- Mike
