blackleg miner
Blackleg Miner
- Messages
- 57
- Reaction score
- 0
Used clone, fires up nice, can get close to idle with slight choke. Cleaned carb twice with carb cleaner, all holes, and high pressure air. Thought for sure I had it dialed in, but still won't rev. Throttle plate wide open and not getting the rev. If I put the choke about halfway, then I can get it to rev a little. I think one of the many holes I cleaned probably didn't get cleaned or something. The e tube is a higher performance one with the 3 or so holes instead of the stock one hole. I did not clean out the brass/aluminum plug like some of the carbs I've worked on. Maybe that's the prob?
Ideas? Thanks
Ideas? Thanks
