Carb cable?
InspectorV
I picked up an old Thunderkart from a friend of mine to fix up for my nieces. Had been sitting for awhile, so I cleaned it up and put on new fuel line, air filter, plug, etc. When I got it, the throttle cable and linkage all seemed to be intact, but there is a cable off what I believe is the governor arm that the other end is connected to a tab which the weld is broken off. Can't find where it broke from, but the piece is the same color red as the frame, so had to be somewhere on the back of the cart. From what I have read, this may be a cable that was connected to the brake assembly. It's the cable in the top of the 2nd pic. The engine runs, but when it fires up, runs wide open, unless I manually throttle it down at carb. If anyone can give me some help here, would be greatly appreciated......Thanks.
Please enlarge the pics by at least 100%. Too small to scrutinize.
From what I know, some karts have a cable from the brake to the governor to serve as a kiddie override. The basic premise is that kids can have a tendency to push both the brake and throttle simultaneously, and this will surely kill the clutch. By having the brake interlocked with the throttling system, pressing the brake will completely nullify any throttle input. This saves the clutch by keeping the engine at idle when the brake is pressed, no matter what you do with the gas pedal.
