They way they are mounted, you are multiplying the weight they are seeing. "750 lbs per inch" is at the shock, but the lever of your suspension arms is probably about at least 3:1, making every 100 lbs like 300 lbs.those springs say 750 per inch ... but I dont think they are that strong.....
Well I have decided to use a little 2.5hp from harbor frieght, with a jack shaft set up...maby...
This is what I have it mind a 12 tooth clutch running to a 40t on the jack with 35 chain, then a 9T or 10T from jack to a 54T on axle with 41 chain.
What do you guys think?? I dont know how to calculat all that ... the tire is a 10" and Idont know how fast it would go.
I would realy like some input befor I spend the money
Well I'll let everyone know how it works out, Ill put it on video. but I would like to know how I should calculate it all out.
