Can't find the correct hub size
MichaelB
I'm looking to build a kart with the wheels I already have but I can't seem to find a hub that is the same bolt pattern. I've seen on amazon spindle/hub/brake combos but they are all 4x110mm and the wheels I have are 4x4". Are there kits for 4x4" or should I just buy 4x110mm wheels?
Not a combo but search the gopowersports.com
4 X 4 hubs are probably the most common size that exist. Adding front brakes complicates it all a whole bunch. Most karts run rear brakes only. What makes you think you need front brakes.
That's cute. I presented 4x4 hubs that accomodate a disc brake and this is the thanks I get. Think I'll go read about Bitcoin fraud.
E Z. Looks like you're in luck. Just checked the forum, and although it's been cleaned up a lot ( thank God ) there was one on there that said something about crypto currencie fraud.
