Cant find it anywhere.
outdooz
I have a Tecumseh Motor. The motor cover is in the dump so I dont know the serial number or model number of the engine. What I am looking for is this part.
Its the plastic part that the air filter screws on to and then it screws into the carbuator. Does any body know what this part is called or where I can get one?
anderkart
Surprise Arizona USA
I'm pretty sure your engine is a OHV14, its family number is 204025A and that part you want is called a Tecumseh 36355 Air Cleaner Body.
Does it look like the one fore sale with these parts? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110647612473
Here's some 36355 Air Cleaner Bodies for sale: http://www.google.com/search?source...nUS369US369&q=Tecumseh+36355+Air+Cleaner+Body
Instead of buying that, another option would be to use a race style air cleaner adaptor and a clamp-on type air filter similar to this setup: http://www.affordablegokarts.com/mm...oduct_Code=AGK190-CE4245ST&Category_Code=AFC2 You could probably make your own filter adaptor or this one might even work with your carb. How far apart are your 2 carb/air filter mounting studs, (measured center to center)?
outdooz
it looks exactly like the first link.
What do you mean about mounting studs?
outdooz
The rings that fit inbetween the air filter body and the carbuator broke. So where can I get new ones?
