cant find a torque convertor or clutch
r97
Measure twice cut once
Massachusetts, USA
it would probably work, but it would have bean better to get an engine with american bolt pattern and all that stuff
r97
Massachusetts, USA
austrailia ok now it makes sense, well you can try with a 1" bore tc or maybe someone has a metric tc
Personally, and this is only my opinion- you're okay with a 1" clutch. .4mm is not a huge margin. He//, if you had a really old engine with a 1" shaft, and took the rust off that old shaft with some sandpaper, by the time it was all polished and ready to go, you'd have lost nearly that much material! Others may disagree, but I think you're okay.
For that matter, I very much doubt a 1" bore clutch is EXACTLY 1", as I also doubt that a 1" shaft is EXACTLY 1". There's GOT to be a little play in the numbers, or it'd be a struggle each and every time you put something on the shaft, or took it off...
Blazkowiez
Kart Aficionado
Houston, Texas
We've run into this problem with Honda engines before, typical clutches wont work. I will say I've had a customer use his kart's shaft like a lathe and with a great deal of patience and sand paper was able to get it down to 1".... may take a while.
Kaptain Krunch
Pro Junk Collector
vermont
25mm is less than 1"...
Gets some .007" or .008" shim stock, to take up the extra room.
Blazkowiez
Kart Aficionado
Houston, Texas
I'm thinking of the reduction shaft(not 25mm), sorry. Good eye Krunch, see I miss things when I post responses at 1am...) I'd just take a sliver from a coke can and shim it, think cheap dude.
coolspot
will i be able to put a comet torque convertor on the engine i got i dont understand how to do it
