cant figure out ratio!!
americansoldier08
Hey everyone, im new to whole go kart thing. I just purchased a kart that has a 13 hp Chinese motor and live axle. It really does suck on takeoff so I’m assuming gearing. I have tried to use the ratio calculators other members have used but with no luck. The cart has 2 chains and 4 sprockets. 16 tooth on the clutch, to a 37 tooth. But then goes to a 10 tooth, then to a 60 tooth on the axle. I know my explaing sucks lol. BTW tires are 21" tall also
kendelrk
redneck engineer
westland michigan
That's called a jackshaft and really opens up gearing possibility. Although I feel with tires that tall a torque converter should be used.
You are already geared extremely low at about 13:1. Your torque should be reasonably good as it is. I suspect there might be another issue here. It could be your clutch is shot or Maybe your throttle is not working correctly. Are you sure you gave up the correct numbers for your sprockets.
I concur. At nearly 14:1, acceleration (even with tires that tall) should be at least adequate. Look for other problems, such as poor fuel delivery (partially clogged carb) or a bad clutch.
