Cannot afford Comet 40 series, options?
slowNloud
Hey guys, I'm new here but I've been doing a lot of research and this forum kept coming up so I figured it's time to register and post.
I own a 5 hp Manco Dingo. The TC is starting to go on it (got the kart free on the side of the road), and instead of fixing it I want to replace it. I know thy can be fixed for next to nothing but here's the catch, time for an engine upgrade.
My grandfather is giving me a 15 hp engine and I want to do a swap on it. I owe my parents a fair amount of money and I've been working 40-50 hours a week to try and pay them back and wanted to do this kart project as a stress reliever but I'm finding it's looking like it'll require a lot of $$.
Is there any cheaper option than a $300 Comet 40? Or does anyone have one they're willing to part with for a fair price? Figured it couldn't help to put this question out here.
Looking forward to hearing from you guys.
fowler
Bullsbrook West Aus
Sell the 5hp and old tc and u have some money right there
What brand is the old tc and engine?
What's wrong with the tc?
U can get a cent clutch but that won't be cheap ether
Welcome to the forum! You might me able to pick up a chinese knockoff of a 40 for cheaper, have a look around. Scout for a used 40, too. But beware- it's still gonna cost you. In addition to the CVT, you're also going to need a jackshaft assembly. This consists of a shaft (likely 3/4") a couple of good bearings, sprockets, hubs, and chain. You will also need to do some fabrication work on the frame to make it all fit, too.
Personally, I would suggest hanging on to your 5hp and original CVT. Tear the CVT down, clean it, lube it- you may not actually need to replace anything. Get it all back up and running, and enjoy it while you square up with your folks. Once they're taken care of, save up your nickels for the 40 and related parts, and do the big power upgrade. See Blazkoweiz's sticky on CVT maintenance.
r_chez_08
Should be in the shop...
Cornwall, UK
I agree with toystory. Even a used comet 40 is probably going to cost you $300 after the additional parts (jackshaft etc.)
slowNloud
How come there's so many additional parts for the 40? In theory shouldn't it simply replace the existing TC that is currently on the kart? The kart runs and I can drive it right now, I'm simply looking to upgrade the power end of it for gits and shiggles. So since there's already a full drive-train, wouldn't a new TC be plug and play? (once I get the new engine lined up).
The current engine is a Briggs 5 HP and I honestly don't know the brand on the TC.
r_chez_08
Cornwall, UK
Post some pics. I assumed a comet tav2, however the tc may be plug and play. However the jackshaft may be the wrong diameter.
slowNloud
I can't get any pictures today, I should be able to post some tomorrow afternoon though.
Is there any way around this? Like an alternative from another machine? or simply a different way it can be configured?
r_chez_08
Cornwall, UK
Not really. Unless you want to do a lot of fabrication and/or modification. You could try and contact cvtech and see if they have anything cheaper.
slowNloud
Let me post up some pictures of what I've got as soon as I can take some good shots of the kart.
If anyone knows anyone selling one in good shape or knows of any way I could even perhaps build one for less, chime in? I'd really appreciate it.
Thanks in advance guys.
r_chez_08
Cornwall, UK
I have an alternative for you-
If you can find a driver and belt to match this it may save you a bit.
http://item.mobileweb.ebay.com/view...md=VIDESC&index=14&nav=SEARCH&nid=46857703966
Edit- if you go on the site of the eBay seller (small engine warehouse) they have the 500 series drivens for $30. BMI have the 500 series drivers for $165. That and a belt would only set you back around $230 compared to $330 for a 40 series. The 500 series are better as well IIRC
The difference lies in the 40's arrangement. Your existing CVT is a self-contained unit. Assembled, it's one piece. Lightweight, compact, no-brain installation. On the other hand, you are limited in powerhandling, physical layout, and output drive options. The 40 is NOT self-contained. It consists of separate driver- and driven- units. You select and mount your own jackshaft in any orientation you like, and choose from a wide range of center spacings. The driver gets mounted on the engine, the driven on the jackshaft. Aside from the belt, there is no physical or mechanical connection between the driven and the engine. Also mounted to the jackshaft is whatever you choose for output. Any size sprocket you require, or a belt if you so choose. Heck, you can put a gear on it, or even a U-joint for a shaft drive final. That's the beauty of a 40- very versatile.
slowNloud
I see the point about the 500 and I'm gonna look into the more affordable parts. Another question, I have a 2nd kart with 6 inch wheels, not the huge 18 inch knobby tires. If I were to make a fast street/turf kart instead of improving the speed on my offroad one, due to the smaller wheel size, does that require less of an extensive drive train? Or is it really just all dependent on the motor?
It's dependant on many factors. The short version is that a small-wheeled on-road kart will generally be okay with just a centrifugal clutch chained directly to the axle sprocket.
slowNloud
Is this a dicey gamble? And what would I be looking at for a CC price wise and what kind?
No, it's an even bet. To verify, post the specs (pic would help) of the small kart in question. Price varies by location. If you're in North America, a safe guess is $50-75 for a basic model.
slowNloud
I cannot get a picture of this kart right now, unfortunately its in storage at the moment. It's nothing special at all, just a flat rectangle no more than 3'x4.5' with 6" wheels on all 4 corners. My grandfather built it out of popular mechanics magazine back in 1959 with a 1.5 HP Clinton motor and got it to go 45 mph.
That's pretty impressive. When you say 6" wheels, is that the rim size or the overall tire diameter? This is a critical factor in determining gearing. To be fair, the description does sound very much like a single reduction/C-clutch arrangement would work just fine. Either way, I'd love to see some pics of this vintage homebrew kart when the opportunity provides.
slowNloud
I believe its the tire diameter. It could be a little bit larger, perhaps 8"? I wish I could just get the old Clinton running again but she doesn't seem to want to cooperate, I've already done some repairs and tune ups. As for the wheels they're just your every day steel hub with a diamond tread pattern tire, like what you'd find on light duty yard equipment.
