Can you help identify this Briggs motor?
freakincage
Winnipeg, MB, Canada
I picked up a Sears Roper on Kijiji (Canada's Craigslist), and it came with this small ancient Briggs motor, but I can't seem to find the info I am wanting. It looks to be about a 3hp and the shaft is 7/8" with a woodruf instead of a key-way.
The number on the recoil shroud is: 60502 941138 6011040
Can someone decipher it for me?
Thanks in advance.
This is what I picked up.
Russ2251
AZUSA:Powered by LAWN-BOY
Very possible that shaft was swapped out at sometime in the distant past.
Some rotary mowers used the same block as the horizontals and many parts were interchangeable.
7/8" IS/WAS common on rotary mowers.
Your engine first appeared in 1957 under a different numbering system.
