Can you Drill Axles to alter where the keys sit?
wardy
Guys help, Im building a shifter. my axle is 50mm but ive flipped it so i can change the sproket carrier to sit inside the bearing as im fitting a mx engine. basically the keyway now fit but not all the way in.can i drill another hole so my keyways can move over one notch??
anderkart
Surprise Arizona USA
I checked out your other thread with pics of your CRG kart. Yes you could but I don't think you'll have to mod the keyway. Your 50mm. axle is the correct type type for a 125cc shifter kart. I think Its stock keyway will work fine without mods, you'll just need to mount the engine a little further inboard from where you've got it located in your pics.
Check out these pics to see what I mean, your axle sprocket wont need to be perfectly centered over the key, the sprocket can be offset to the right quite a aways and the key will still be plenty strong to hold up...
wardy
Thankyou very much, ive actually ordered the same rear sprocket and carrier as your pic and i think itll give me a bit more space so cheers for the heads up
