Can this motor be saved?
zogthegreat
Lake Wales FL/Montreal QC
So I'm finally finished with painting and assembly:
It looks good, but it seems to be lacking a certian Je ne sais pas quoi.
Ahh! Much better! :)
zogthegreat
Hmm, I'm having a strange problem. I put on a new carburetor and tried to start the motor and the carb started leaking gas out the throat. I figured that there was a problem with the float or the needle, so I swapped out the carb for an old one that I know is good and I had the same problem. I took both of them apart and they look OK. Any suggestions on how I'm messing this up?
zogthegreat
Gaskets are potentially broken....
All of the gaskets are new, however I did reuse the spacers on both sides.
I'm seeing the dripping mainly from the motor side, but when I remove the air filter mount, I see a large amount of gas/flooding in the carb throat on the air filter side also:
I think that I have the gaskets installed in the right manner, I'll recheck tomorrow morning.
zogthegreat
OK, I'm going insane here! :mad2:
I borrowed a carburetor from one of the groundskeepers lawnmowers and I have the same problem! :mad2:
I know that I'm missing something basic here but I can't figureout what. Here is how I have the gaskets setup:
There is a gasket on the cylinder head, it's gray, so it's hard to see. I checked a diagram from partstree.com and the only thing that I see that's different is the gasket that goes between the carb and the spacer for the air filter:
:censored: :censored: :censored: :censored::mad2: :mad2: :mad2:
supermanotorious
Winchmaster 5000
New River, AZ
you shouldn't have fuel just pouring out cause the flanges aren't sealing, have you checked the carb bowl? made sure the float needle is seating properly?
zogthegreat
It's alive! My creature, it's ALIVE!!! Bwahahaha!!!
Well after trying 4 different carbs and getting the same results, I decided to try something different. The head that I was using was the one that I had ported and polished. I pulled that head and swapped it for a non-ported and polished and the motor started with the second pull. :)
Now, of course, comes the question "why". If anything, I should have needed more fuel coming into a ported head. Does anyone know what the problem here is? I really would like to use the ported head for my summer project with my daughter.
But at least I know that I don't have 4 bad carburetors!
IT'S ALIVE!
[url]https://youtu.be/1qNeGSJaQ9Q?t=138[/URL]
Did you check to see if you damaged the valve seat when you were doing the P&P?
Did you lap the valves?
Did you take any material off the head to raise compression?
zogthegreat
I did lap the valves, I'm of the school that if you have a head off, lap the bleeping valves. I also used Prussian Blue. Essentially I did it like I would a car head.
As for the head surface, it looks fine to me, but I will go get a piece of glass to be sure.
I didn't remove any material from the head surface. The head that I swapped was actually from a Honda GX160, so I think that it's slightly smaller than the stock clone head.
I'm going to dig out the other 6.5 clone head that I have and test with that today.
KartFab
Dallas, TX
Just a few personal thoughts on porting:
if you hogged out the port runners, you killed port velocity, inadequate port velocity doesn't give a strong vacuum signal at the carb, resulting in a lean condition, and poor mixing of air/fuel. If you buy an extra idle pilot jet, you can drill it out and see if it makes any difference.
If you nicked a seat, you lost compression, so it wont run.
If you set valve lash at the wrong spot, you could get non-start.
Head gasket could not be working/blown.
Just thoughts, maybe none of them are correct, or the actual problem.
zogthegreat
Sounds like you know what your doing. What about valve train? Is the lash set right?
LOL, thanks, but if I knew what I was doing, I wouldn't have to ask for so much help! :ack2:
I set the intake for 0.004 and the exhaust to 0.006. With the Honda 5hp head, motor runs fie with those settings.
I don't see any nicks around the valve seats, when I used the Prussian Blue, they looked fine. I thought that I went fairly conservative on the porting, (compared to what I have seen):
I left the valve stems alone, I mainly worked on getting the roughness off, making sure to leave some roughness for the intake.
I agree that I should be running lean with the port and polish, that's why I'm confused about the flooding. I used the same head gasket for the Honda head, so I can eliminate that.
Ok Zog. Riddle me this.
You had a leaky carb, you swapped on a new carb, it leaked also. You even borrowed a working carb and it leaked now too?
Then you swap heads and now it runs?
What happened to leaky carbs?
zogthegreat
I tried all of them with the new head and they ran fine, (I actually tried 4 different carbs).
This is why I'm confused, (well, one of the reasons! ;)), if one or two carburetors had flooded, OK, I have a bad float or something. But swapping the heads removed the flooding on the carburetors. That just doesn't make any sense to me.
