can it be fixed
skikman
hi everyone.the pull start broke on my go cart.my mate said he would start it with a drill and scocket.so he put it on the bolt in the center of where the pull start goes and spun it clockwise and broke the bolt.i know now he should have spun it anticlockwise but now its broke.is there anyway to fix this [easy] so i can do it myself?
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
I've had great luck with left hand drill bits. My screw extractor set came with a left hand bit matched for each size of extractor, and frequently while drilling a broken bolt/stud the bit will spin the broken piece out of the hole. I've only had to use the extractors a couple times :D Give it a try, you should be able to purchase left hand bits from any industrial supplier that sells fabrication or machining tools & consumables.
Bluethunder3320
broke exactly what bolt? a bolt that attaches the recoil, or the bolt on the crankshaft itself?
anderkart
Surprise Arizona USA
skikman, before you try the other suggestions, you might be able to just unscrew it. Hopefully if the treads aren't jammed, you can just use a small, sharp pointed center punch and a hammer to lightly tap on the outer edge of the bolt to get it to turn and unscrew. Doesn't always work but its worth a quick try anyway.
jandj
Williamsburg, Va
Left handed bit has saved my *** more than once over the years, as has the "tap it with a punch/chisel" method.
It's not always as bad as you (naturally) assume it will be!
