Can I MIG weld 7/8 pipe to 7/8 mild steel?
panel
Newbie :)
Victoria B.C. Canada
I have a frame made up from 7/8" stainless but have the motor mount and seat mount,head tube + everything else just plate steel etc. Do I have to get this all Tigged? Can I just use my Lincoln 140 for all of this ?
This is for a mini bike frame like the one in my avatar.
For the most part, no.
Stainless and regular carbon steel won't bond well in this case, regardless of process.
Oh and a shout out to my local brother... Just right across the straight from ya...
Cool looking VW too.
That's ironic... I did look at that site... To clarify...
I'd reckon a guess the structure couldn't handle the neck joint weld.
Tabs and other mounts, ya.
Yup, just keep an eye out for cracking that may occur after some hard use. But if done right it will be a long time. :thumbsup:
:useless:
x5050160
Crystal Lakes, MO
Get a torch on the carbon side before and after welding. Don't let the joint cool too fast or that carbon steel could get brittle. You can also weld with a helium based shielding gas to help with heat transfer. You will also need to use a higher voltage setting than you would use with carbon steel because stainless doesnt conduct electricity very well. I would tack top, bottom, left, right. That should help with any distortion or shrinkage issues. Also i would avoid breathing in those stainless fumes, I don't think chromium is good for the lungs.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I had some 1" angle I used last year to make a jackshaft mount. I welded mild steel to it with my mig. I did not realize it was stainless, till I tried to Drill a hole in it! Anyway it welded just fine and is still holding.
