Does anyone see any issues in using a small shim to allow the use if a 3/4" clutch?
No BUT it's very possible to fit a 5/8" clutch to it...
5/8" = 15.875mm; you measured a tad over 18mm which is a difference of around 2.2mm, that would be a lot of rust so, it's possible it is, in fact, an 18mm shaft but, we won't know until you clean the shaft...
The simplest way is to start the engine & hold a piece of emery on the spinning shaft; it should be spotless in under a minute...
