Lets call this read a plug day ! Kart runs like crap 3/4 throttle and down. And this plug has at least 30 min. Run time on it ! I wish it was black or white. At least it could be read correctly.
the idle air jet is turned way out so everybody said to go one size smaller on jet, BUT it ran a lot worse with smaller one so i put the other one back in. If you floor the pedal it takes about 5 to 10 seconds to hit the power band but if you stay in the power band it runs awesome and breaks the tires loose in every gear.
This is on my 1991 KX125 engine in a shifter kart with a FMF pipe. It is suppose to have a lot motor work done but i don't know what. I am running 110 race fuel @ 32 to 1 oil mix.
The carb is from a 1992 and is a Keihin 37mm from what i have found. has a 158 main jet and a 50 pilot jet.
