Cam stuck.on shaft of driven pully
preston
Im trying to remove the cam from my driven pully on a pretty much new 30 series.torque convertor. To play with spring settings and possibly switch to yellow spring. I took off nut and snap ring but thing will not come off. It looks as though 2 sides of the hole that allows it to slide off shaft are undersized . And other two long sides of the center hole in the cam are fine . So it looks like it would slide off on two long.sides of shaft. But on other two sides its getting stuck. Can't even see a separation in cam.and the shaft like I can on two long sides of shaft. Does this make any sense to anyone. Hope I explained it well. I'm scared to put the pry bar on it and I don't have a puller of any kind to use. HELP PLEASE.......
preston
Ok i got u. Gonna go pull it off real fast. But literally just now went to hit a donut and motor shut off. Now won't crank. Pull cord stuck like its locked up. Could it be I sheared the key in the flywheel. . I can push it and it moves
preston
I got it off and fixed my motor being locked up problem as well. Not sure what it was that had my flywheel locked up . But I let it sit.fpr couple hours and fired right up like nothing ever happened .
