Cam selection
Copykat
Contemplating going the next level with the clone motor i have. There are alot of cams out there but not sure which one is good. I know a cam change could actually hurt performance if it doesnt work with the current mods.
I have upgraded to 22 lb valve springs with 1.3:1 ratio rockers. No governor, 8 deg timing key and a 68 jet in the carb. It has a pipe with a RLV silencer.
I plan to port a head and wonder what cam would work well with the mods to really wake this motor up. Not interested in high RPM power as most of the time its not running that high. Looking for low end power.
Any suggestions?
Thanks
Hi, first get a billet conrod and you should really get the billet flywheel.
The 8° key is for rpm not for power, (in fact you loose low end power with advanced timing)
Anyway, what you want is a longer timing on your cam, not at a different timing.
so that your valves stay open a little longer, (slightly wider knuckles)
I think that'd be a MOD1 for example IIRC.
the more compression you have (better filling rate, ported and maybe milled head)
the more stress you put on your conrod, and the stock one doesn't like that.
And while you're at it, the flywheel isn't made for the rpms either...
so get a new one (oh.. if it's the ARC flywheel remove the AT key it has 8° build in ;))
