cam reinstall problem please help
kendelrk
redneck engineer
westland michigan
after a total governor delete, my cam has fallen out. i have no problems with timing, but the push rods i beleive there called are just pressed up against the engine block. and if i try to pull them down they dont want to come out. what am i supposed to do? heres a pic of what im talking about, arent they supposed to make contact the cam?
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
I had a problem similar if not the same. You need to take the rods and push it through. It's tricky. You need to use some WD40 or a squirt of some 4 stroke oil. It's just stuck and it doesn't want to come out for now.
r_chez_08
Should be in the shop...
Cornwall, UK
Take off the rocker cover and put the push rods back into the dimples on the rocker arms.
Reinstall cam and side cover and check valve lash.
If you do just as Brandon says, your motor will be unlikely to start as the valves will not open.
kendelrk
redneck engineer
westland michigan
have just done this, everything is back together now, but i have absolutley no side play in the crankshaft, does this matter?
