Calling Feliks From Krakow
Feliks
Krakow
http://www.iaea.org/newscenter/focus/fukushima/statusreport270412.pdf
The new rule :
No Atoms for Peace. Atoms only for War
As teh proved in practice, the spent fuel pools are more dangerous than the same reactors. Probably because of this need not be the same as the reactor containment, ...
Because the fuel in the reactor can be serious, but nonetheless the same fuel in the swimming pool of the spent fuel, no longer is dangerous....
Probably because the spent fuel pools are similar to "garden pools "
And again the Pyramids ...
And the few words the truth about " swimming pools."
http://everist.org/archives/Fukushima/2012...ge_of_Fuku3.htm
Regards Andrew :confused:
fowler
Bullsbrook West Aus
wicked pic
this thread pretty much died a very long time ago
no on has posted preditor info since page 2 (6 11 11)
this is andrews thread
he puts some really out there but intresting posts up
he has been here since mid last year providing entertainment u have only joined 4 months ago
bighead
Pacific Northwest USA
wicked pic
Amagine the rumble sounds this would have made while moving. Amagine being the car right on the edge?
The trees and top of the slide is untouched.
Or amagine riding the slide down by standing on top?
From the concrete on the left side I bet there was a wall holding it all back. Then gave out.
fowler
Bullsbrook West Aus
ar yes i see
i thought there might have been tunnels but yes very big wall
that would have ben wicked to see
i like the people on the road thinking **** what now
i remeber as a kid we leassed anoughter farm off some freinds and on the fram was a granite montain maybe 100m tall
we live 20km from this farm and one night during dinner we heard a low rumber like thunder
next week we went to check the water and found the moutain had had one side slip away into the national park
the peice would have been 150m long 50m wide and 20m thick
we just stod and looked at it for ages
incredible
bighead
would be a challege to clean up as well. I do not think they would let large trucks drive up to the rocks. Looks like both sides has bridge on each end.
Also some type of foor bridge in the back?
I would not be standing where those people are. Unless I had a piller under me. Four roads in that spot too.
IDK all that concrete could be the roads? But it's up to high right?
Here is a good one. Amagine if it was over a few hundred yards and crashed down the cliffs? Looks like some big chunks went between the roads. Amagine just fishing down there as a car size concrete slabs land 10 feet from you?
fowler
Bullsbrook West Aus
yes i would think they couldnt get earth moving gear over those bridges esesially as the forground one may no longer have any foundations
they should be able to get gear dowm the ridge
but only earthmoving gear not on road trucks
u would be surprised what they climb with those cat 740 artic turcks
the poor fisherman would be sitting there all day and finally gets a fish
reels it half way in and its hit with 10 ton of concrete
the real FML moment
i would like to know where this was so i could read into it a bit more
by the size of the road it must be a major artielal link between two huge cities
there are no roads that big round where i am and in a capital city
surly it would have been a huge killer to both cities
Feliks
Krakow
Feliks said:
And my animation, showing what you can do in 4 Fourth swimming pool in Fukushimie.
You need to build a new building, to the basement of the reactor building to insert with three new reactors, only to store the fuel. They manage any guarantees when possible earthquakes.After filling all the water also will be a guarantee of the & span settlement.
Andrew: Wykupu:
Feliks
Krakow
Whether engineers will pretend that the atomists still do not know the new inverter UPS Technology on batteries, which in the case of a power failure, it is ready within fractional seconds to the provisioning of the full effect of emergency systems ???
Of course, some diesel then can long function.
But I think, with this reason for savings, because and so nuke is already insanely expensive.
http://www05.abb.com/global/scot/scot235.n...chure_rev_c.pdf
Andrew:confused:
bighead
Feliks Can you post your information from the other closed thread to this one?
I am very interested in your stuff and enjoy reading it.
Could you talk about your engine design?
Regards and thank you.
Last thread should have not been closed. If Feliks post here then cool. If not we lost a very interesing member. It was one of my most like threads.
If you enjoyed Feliks stuff. The PM him and ask him here. I did. Would love to drink a few beers with this guy.
Feliks
Krakow
In order to provide the reactors in Fukushime from the bottom you have the mechanical tunnel.
Then insert the two meters in diameter with 20 tubes. , Do the holes from the top and side, and on the bottom line fire resistant ZrO2. For large pipes enter the small tube to remove radioactive leaks or cooling corium had reached there...
http://www.herrenknecht.com/fileadmin/redaktion/PDF_Downloads/Direct_Pipe_Fly_GB_09-12-21.pdf
http://www.herrenknecht.com/fileadmin/redaktion/PDF_Downloads/AVN250XC_AVN700XC_DB_GB_08-10-29.pdf
Certainly not the cheapest, but it will give guarantees that the radioactive materials do not enter the land and ocean
Regards Andrew: Cheers2:
Feliks
Krakow
I wonder if to ask if these two smiling at us men to graciously evacuated their asses out of this car, it would be possible instead of carriage them to produce some electricity for us? Since drivers are not needed, because the car is harnessed to the treadmill and drivin in circles .. But one thing is certain, that such a vehicle driving the external energy, we will have the wind, regardless of the weather ... AJ is here the energy produced is sufficient to maintain the treadmill speed, it will be good .... And maybe even a few kilowatts for us is for our use ....
And it is always, regardless of the weather ... I do not need to go to the desert to breaking records. This can be done on the treadmill near the house...
http://www.youtube.com/watch?v=bkcn8ZkvKKc&feature=plcp
http://news.discovery.com/autos/how-do-wind-powered-cars-work-111207.html
Andrew: D
Feliks
Krakow
http://www.rcgroups.com/forums/attachment.php?attachmentid=777461
Of course, the fuel will be coal dust....
Originally posted by Anth
Of course
I hope you will also agree with this, teeth were the least moving parts. The 5 MW windmill should be placed. Mounted on the ends of the arms jet frame. (ends reach such a large fan wheel 1 Ma), so the jet frame will fit well ... It will be a "small" treadmill
http://en.wikipedia.org/wiki/Ramjet
Andrew: D
http://tipjet.com/tj_pho_gallry.htm
Feliks
Krakow
Ramjet symulation (upper green) Need Java
http://www.grc.nasa.gov/WWW/k-12/VirtualAero/BottleRocket/airplane/ngnsim.html
As I see massive construction that are to demolish the building of Reactor No. 3 is me shivers go ..
Certainly the building suffered the most, because it was the biggest explosion. So the walls are certainly very weak, and it seems to me that the water in the pool of fuel remains a miracle there is to do there can not be inspected, that does not mean that the building is sturdy ..
Therefore, demolition should in my opinion not cause additional shocks, and be carried out as gently as possible ... Heavy construction equipment, rather they should not be used ...
They are after all modern methods, such as cutting concrete with water. The company offers cutting up to 3 meters ..
[ur]http://ajaks.eu/en/services-for-civil-engineering/hydrodynamic-demolition-of-concrete--hydrodynamic-robots.html"]http://ajaks.eu/en/services-for-civil-engineering/hydrodynamic-demolition-of-concrete--hydrodynamic-robots.html[/url]
I do not want to think what would have happened, if as a result of the vibrations, the resulting leaks in the fuel pool and the water came out of it ... Almost as a result of radiation inside the building and its three filling remains, you can not to re-seal it. ..
Therefore, even mild disturbances such methods may be used: diamond cut rope ..
http://www.hilti.com/data/editorials/-14620/ds-wss 30 leaflet e.pdf
https://www.hilti.co.uk/fstore/holuk/techlib/docs/DS-WS10 en.pdf
http://www.youtube.com/watch?v=lZ04OdpmJ84
http://www.youtube.com/watch?NR=1&feature=endscreen&v=N54madabs9s
http://www.youtube.com/watch?NR=1&feature=endscreen&v=GVI8Z5grdOw
http://www.youtube.com/watch?feature=endscreen&NR=1&v=I8xoHvhiA2k
Andrew;)
fowler
Bullsbrook West Aus
needing some clarification here
haveing never reasearched nucler power and put less time into the fucashima disaster, i dont fully understand it
obviously they are demolishing the damged structures without disturbing the old fuel rods in the cooling pools (or whatever the name is
what accually happens if they are removed
i know they heat up and realese alot of heat and some great radioactivity
but why cant they move them out of there?
move the radioacvite stuff away from the site?
Feliks
Krakow
Here, the photo of the engine and Abart, for those who have doubts about the hight engine of my..
Andrew:)
Feliks
Krakow
Did you know that it looks like the latest engine to produce electricity using any fuel, such as coal dust. Attached to the treadmill, skip step steam,,,
The end of the treadmill must be about 1 Mach speed, which at the shoulder of 50 meters is normal ... every second ..
http://www.youtube.com/watch?feature=player_embedded&v=CGcRgEuCocQ
It's not like we all have to fly, but the current a good thing ...
Regards Andrew :D
Feliks
Krakow
Here is a reworked so as not to put unnecessary drag .. A bit like a UFO. Still on the edge of the "plate" can fasten some neodymium magnets ....
With these dimensions of 10 MW ....
In preparation for the new job of atomic physics, they can calculate the efficiency of the this power plant ...
Regards Andrew: D
