Hiya fellas, new to site first post. First, the wealth of knowledge here is fascinating. Impressive to say the least. So, a buddy of mine gave me a Taiwanese Go-kart, built by "Wu's Agricultural Machinery Mfg" no motor. Got a good running Tecumseh 7hp at garage sale $25 w worn out centrifugal clutch 10 tooth (teeth 5/8 " apart).CC is 3/4 no tapped hole. Want to go CVT. This Kart has a forward neutral reverse transmission 2.25:1. that has a 3 1/2" v-type pulley on the input and a 11 tooth sprocket on the output (teeth 1/2" apart) that drives the axle with a 21 tooth sprocket. Tire size is 12". Its mainly for my son but I'm sure I'll spend plenty of time behind the wheel. I'm 170 lbs. Also picked up newer good running B&S 5.5 hp or 9 ft/lbs OHV motor that has a 6:1 reduction box on it. What type of CVT fits 3/4 w no hole? Can I put a driven pulley on my trans and drive pulley on my motor, symmetrical or asymmetrical. Do I have to raise trans so its parallel to engine?
Are my ratios ok? Pics included. Thanks Chad
