Buying a new Carb. Quick question.
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
So I stripped the jet and broke a tab in my dek 11 hp generator. I'm guessing this is a gx390 clone based on the looks of it. My question is.. can I use this carburetor with this 11 HP generator engine?
I'm gonna say yes because it looks identical, both the engine and the carb, but I gotz to know before I got ordering sh!t that I'll be stuck with.
EDIT: Actually, stupid of me to think that the gx390 carb would fit. I'm guessing this is the one I want to buy for my 11 HP Honda clone?
http://www.ebay.com/itm/HONDA-GX340...ltDomain_0&hash=item3a696ddeeb#ht_1272wt_1168
Thanks.
r_chez_08
Should be in the shop...
Cornwall, UK
You may get some more power out of the generator with the gx390 carb, I expect it has a marginally larger bore.
DCProductions
Cockney Ragamuffin
Louisiana, USA
If I'm not mistaken, the 390 and 340 have identical carburetors (like the 160 and 200). The difference in stroke/bore/etc. is what varies the power. I am basing this judgement off of the commonality between the 160 and 200, so it may not apply to the higher displacement engines.
I believe the normal route to take regarding these engines is a 30something mm Mikuni/Mikuni clone carb.
r_chez_08
Cornwall, UK
I know you know your carby's but, to me, the bolt patterns look opposite
Yeah, that's because one your looking from the throttle butterfly side, the other from the choke side :arf:
I would not bother with a mikuni, it's a generator! Buy if it was going on a kart, go ahead!
