Ebrownie
I have thought about that hellion. A couple things came to mind
1. Weighs half a ton (old lawnmower)
2. No suspension (springs over kingpins)
3. It would make the go kart pretty ugly
I got it pretty much figured out. Whatever size bearings I get, (unless 5/8", then I will buy spindles) I will buy some axle for that ID of bearing. Then I will weld that axle to the tube thing that goes over the kingpin. I will drill and tap a hole in the end for the hub cab bolt.
In theory, it should work.... or not. What do you think?
Sorry for the slightly vague description, I tried. If my brain could print out pictures, I would add a picture.
