Burning wires.
Gokartjoe
Had a question about the wiring on a go-kart. When I hook up the positive cable on the battery my wires start to burn up. I have a three phase regulator rectifier is that causing the problem of the wires getting burned up should I replace it or is it the CDI. Thanks any help will be appreciated.
Gokartjoe
it's a cn250 motor .. don't know the exact brand of the go-kart but if anyone knows I would help too. Thanks
Texan
Senor Member
Deep In The Heart of Texas
Don't know anything about the kart or engine, but sounds like something is shorting out. Does your kart not have a fuse? Follow the burned wires. Do you have an multimeter?
Electrical is extremely hard to diagnose online through pictures.
Your gonna need a meter and start probing. Something sounds likes it's grounding out.
I'd start at the battery and follow every wire till you find damaged wire harness or a faulty part like a relay or switch.
anderkart
Surprise Arizona USA
Tell us the symptoms of how this problem first started, that might give us some good clues...
What wires are burning? - Some of the smaller wires, or do you mean the larger battery cables?
___________
If the battery cables are burning, the first culprit I would suspect is:
The starter is shorted, and this damaged the starter relay by melting/fusing its internal contacts together, so its now constantly sending power to the defective starter.
Try disconnecting the cable from the starter and see if the short goes away.
most vertaily a short circuit..
where cannot be guessed by what little info you gave us.
BUT..there's a more or less easy way to tell:
the burned wire!
No really.. the hottest spot (where it burned first)
ist almost exactly half way between the positive and negative poles it gets fed by..
So if your burned spot is a foot from the battery terminal (in case we talk uniform wire gauge)
it'll be a foot from the culprit part/connection.
only exception worn insulation-short.. they burn on sight
PS most likely there's a misconnection on some part.. something grounded that mustn't be,
CDI installed incorrectly or a wrong one etc...
I didn't know this. Thanks!
since it's an overstatement really ;)
But on very simple and straight forward wiring harnesses
(like I would want to assume on a kart like that)
it might be just good enough to get an idea where to search for the culprit ;)
Oh just in case someone misunderstood..
if you have a burned wire (by accident) it can give you a clue..
DO NOT knowingly reproduce such short to get such burned wire ;)
Everytime you repeat the mishap, the next weakest link in line will likely go/blow and you need to repair/replace another something.
Karttekk
Elizabeth, PA
Like Sid mentioned, check the CDI module. Most karts use an AC type, American Landmaster or Manco use a DC CDI. If the wrong CDI is installed it will blow a fuse or the CDI immediately. Disconnect any ignition components and any lighting to eliminate any shorts. Connect the battery cables then connect one component at a time while watching for any wires starting to heat up. The culprit should show up this way. Check the key switch also for melted wires and make sure the starter or relay isn't shorted. Process of elimination.
Thanks
