A torque converter is pretty much required, and on top of that some engine mods would probably help with a kart that heavy. Speaking from experience, swapping the cam out on a 196cc powered Blaster 65 dual suspension pig was one of the best purchases I made.
This is not directed at you cavfire....but you opened the door...extra hp does
not help in any way shape or form....
To put in the simplest anology I can think of: you have a V-8 in a four cylinder car that's burning up clutches....so...building up that engine for more horsepower
is going toHELP? ??
SOOOO....to continue with the analogy...it has skinny rear tires....soooo....put on some bigger ones....
(That's basically saying "put on a torque converter ")....
Sooo....what's the point of this analogy? The real problem is the 4 cylinder drivetrain. And the real problem here....(and so often otherwise) is GEARING! !!!
That's the analogy of the 4 cylinder car...It's just wrong for the application....and unless you address the proper weak points....you can throw a lot of money in the wrong directions....
Burnt clutches aren't a problem....they're a
symptom ....
