Bunch of Parts
TKart
New Aftermarket GX270 9hp Cylinder Head Ready to run
$45 shipped
Steering column, tie rods, spindle and hub assembly.
Column measures 15.5''
Tie rods from end to end are 27.75" while attached to column
Spindles and hub are 6.5" from mounting base to threads.
Overall assembled length is 40.75"
Spindles and hub have zerk fittings and can be greased
$65 shipped ( I also have some longer linkage rods)
Brand new aftermarket GX 200 crankshaft, rod, piston and ring set. Includes wrist pin and clips. Standard bore piston and standard rod length
$55 shipped
Used Genuine Honda crankshaft for a Honda GX270 9.0 hp engine with a 1" output shaft. The journal shows very light signs of wear and was pulled from the working engine. The engine this was pulled from DOES NOT HAVE A BALANCE SHAFT.
For used WITHOUT A GOVERNOR
$20 shipped
Brand New Genuine Honda Crank for GX270 with balancer and angular cut gears. I have two of these.
$70 each shipped.
Brand New Genuin Honda Crank for Gx 160 5.5
$60 shipped
2:1 Gear Reduction Unit Wet Clutch for the Honda GX270 9hp engine. This is a rebuilt with internals that are pretty much all brand new with ZERO hours of run time. The frictions and plates are high quality, can take a lot of abuse and endure extreme high temperatures before flinching. The unit will be shipped dry so it is your responsibility to soak the frictions in oil prior to running it, torquing the case to proper spec, filling with 10w30 motor oil to proper level and installing on your engine. All info about this unit is available on Honda's site.
Here are all the new parts in the case.
New frictions and steel plates,new case, new springs,new retaining clips, new gasket, new case seal, new bearings, dip stick
$115 shipped. I have 3 of these units left.
I also have 4 running concession style karts with honda gx270 engines. 2 of them have engines that have new bottom ends the other two run fine. All of them are governed and have 2:1 reduction units on them. Karts have dual hydraulic disc brakes floating axles roll cage and seat belts. They are heavy karts but can be stripped down easily. Asking price on running karts is $350 per and must be picked up. Asking price on rollers with no engine is $150.
Located in Southern California
Paypal only on parts that can be shipped.
Cash in hand on Karts.
* if you guys need anything let me know because in a few weeks most of the old chassis are going to be cut up and scrapped.
