Slamwoef
Good day builders n riders.
I must admit I have started this build a month or 2 ago.
I have gone trough extensive calculations to get the chassis the rite length. Using formula h(m)8=Length. AKA Hmmmmmmmm ill make it this long.
I have attached some photos plz let me know if they don't show up.
The chassis is made from 25 x 25 x 1.6 mm tube its a double stack chassis with the lower section being smaller so that it could be braced in some sort of fasion. I spaced the front end very close together so that I can have a compact steering system ( also building this) and enough controll arm movement without sacraficing wheel width ( about 1.1meters)
The wheels are 10" steel rims for now but they will become Quad rims and tires by the end.
Power is passed to the rear wheels from a 100cc Yamaha 2stroke making about 10 Hp trough a 4 speed box. This is just a temp motor as I am also busy with a 450cc Suzuki Twin that will go in should be good for about 40+ Hp, but that still needs a lot of work.
Braking is only on the back as a go kart should drums for now. Disk will be on when the 450 comes.
Front end is double wishbone with pitman steering system, I still need to fit the shocks and springs but that should be easy. Its a bit complex but it works 100% will post photo of that by the weekend.
Sweet guys and gals.
Please let me know what you think. All comments welcome.
