creakingcane
- Messages
- 2
- Reaction score
- 0
HI
I have just put together an off road buggy which is powered by a honda GX200 motor, governor removed stronger valve springs fitted, I have fitted a maxtorque centrifugal kart clutch which has 16 teeth and a talon sprocket with 72 teeth and it has 22" balloon tyres. My problem is when at full throttle the kart just about gets going on the flat but as soon as there is any rough ground or very minor incline it just grinds to a halt...
I assume the ratio between the axle sprocket and the clutch sprocket is wrong? any suggestions as to what I can do..I am not looking for very high speed just more torque so I can keep going over fields etc....
also is there a right way round for the clutch or should it work when spinning in either direction?
I hope somebody out there can help?
thanks
Mike
thanks
Mike
i would reccomend a torque convertor too, but depends on your budget.
