buggy design
bajagokart
Red Deer, Alberta, Canada
ya i wouldnt recommend the one bar up the middle! no structural strength at all! i would do bigger triangular supports on the side or modify the frame so you could have two supports, one on either side
mike75925
thinker and tinkerer
Alto, tx
all vehicles flex to a point. it is keeping the flex in check that will make it last. dragsters flex quite a bit from what a car does. you can't send something that fast and be rigid. it would break a lot of welds. i've been building metal buildings of late, and the 3x3 seems more rigid than the 4x4. it definitely takes longer to cut.
theo
I am a good welder. I don't think that's sufficient, not for a single member.
You could be right, I was thinking of weight, maybe .100 wall? I don't think that there will be a problem with welds, I'm more worried about twist. The bottom tube could be strengthened by using 2 1x2x.083 rectangle welded side by side to give a internal web which would be .166 thick.
theo
I worked on the design and now came up with the bottom rail of 2 1x2 with a 2 inch space between them, now the 2x2 can fit in between them which makes the bottom frame rail 4" wide and will stiffen it up a lot.
khank1995
I would just put the engine on the swing arm would be easier NICE DESIGNS THOUGH!!!!!!!!!
