Budget Shifter Kart
Sumnig66
Hello so I have a 1999 Tony Kart Extreme and I'm looking to find a cheap engine to put in it just to have some fun well I build a CR125 to put in it. I have been looking at the Piranha 140cc 4speed in it but I'm not sure if it will push me. I am 200lb and would be happy if it would do 45-50. Any info would be awesome and I am definitely interested in any suggestions! Thanks guys
anickode
S.E. Michigan
I recommend using a predator engine stage 1 or 2 with a juggernaut but with a 4-speed shifter, it will definitely get you to at least 40
What? That's not how it works. The "4 speed shifter" is integral to the engine.
A cheap predator with an intake, exhaust, rejet, and governor removed would scoot you around just fine. A plain old clutch would suffice. There's absolutely no need for a juggernaut driver... If you wanted to use a plain Jane TAV2 you could, but it'd be a tight squeeze.
You'd have to put a mount plate for an industrial engine...
Another option would be something like a 125cc 4 stroke pit bike engine... Not as cheap an option, but it'd be simpler to mount and plenty fast - give you the shifter kart feel and the nice compact engine.
Sumnig66
The Piranha 140cc 4speed is a pit bike engine and it's only about 400bucks brand new. You think that would be strong enough?
anickode
S.E. Michigan
They make something like 10 HP. I've seen figures as high as 11-13. That engine should get you your 50mph goal right out of the box if you gear it right.
Mr_mcrib212
Inmate #2148
Southern California
If you want to go REALLY fast, use a 200cc 5 speed, that will get you up to at LEAST 60 but that depends on your budget, these are 600$ and make about 16-18hp and also how concerned with safety. If you do, please put a harness on it and wear a helmet
anickode
S.E. Michigan
LMFAO obviously you don't really know what you're talking about here.
Shifter karts normally run with 40+ hp engines at speeds over 100 mph, hence the 4 wheel hydraulic brakes.
And a harness on a kart that hasn't got a ROPS is a HORRIBLE idea.
Sumnig66
I still need to order a sprocket hub what size sprockets you think I should get?
Mr_mcrib212
Inmate #2148
Southern California
If you want higher top speed, go for a smaller sprocket like a 50 tooth or something, for a slower top speed but higher torque, go for a 60 or 70 tooth
anickode
S.E. Michigan
It really depends how the thing is geared. Being a bike engine, it's meant to spin quite a large tire, so you might need to look as low as a 1:2 or even 1:1 ratio. Really need to know the internal gear ratios and oem sprocket size.
