If you instal most any other brand/model of carb there's a very good chance your engine will never run at its best. I suggest you find the model numbers stamped into your old carb, and then either buy a kit to rebuild it or buy the exact same model of Tillotson cab as a replacement.
The company that made your engine spent a lot of time choosing what carb worked best, unless you truly know what your doing, you'll never find another brand/model of carb that is better suited to your engine than the model it came with.
Here's some info to help you find your carbs model numbers:
http://www.tillotson.ie/help.php
You should probably research info found here too::
http://www.google.com/search?source....,cf.osb&fp=569ce67a91048ad5&biw=1024&bih=556
