BSP Clone Fuel Issues
gokarttimmy
Pittsburgh,Pa.
I have a yellow BSP clone from ARC Racing.
It is basically out of the box with a billet flywheel and a short header with muffler. I used the RuXing carb and changed the main jet to a 36.I also changed the idle jet from stock-but I do not remember what size it was. It will start and run okay, but at high RPM it spits gas out of the carb. The Autolite plug is also black when removed.
What do I check?
Valve lash? I have it currently set at .002 intake and .003 exhaust.
Jetting?
Any advice is greatly appreciated.
gokarttimmy
Pittsburgh,Pa.
By putting it back, am I to assume that you mean putting back the stock jets?
I forgot-how about the emulsion tube? Should that be returned back to stock also?
Joe-405
Enjoying New Projects
U.S.A.
Smaller main jet and it needs a .022 low speed jet.
Did you put a different e-tube in it cause that changes the Jets also.
And ditch that autolite plug for a ngk bpr6es
I have 3 of those engines. None of them have that big of main jet.
---------- Post added at 10:37 AM ---------- Previous post was at 10:33 AM ----------
Wait a minute.......... How do you know it's spitting fuel out at high rpm ? That's physically impossible unless your not running a air cleaner ! And that just opened up a whole set of extra problems.
gokarttimmy
Pittsburgh,Pa.
I'll try changing the jets back, as well as the tube. How do you like the BSP engines? I see them as a good alternative to a complete build of a 212 Predator. I'm not going to join an official race series, so I can run whatever set up works-mostly parking lots and the occasional track test n tune.
I had it running today on a parking lot and when it is in the upper RPM ranges, there is a vibration that literally shakes my eyeballs....Something to do with harmonics or something....
Joe-405
U.S.A.
Vibrations are normal for small engines.
And I've had a few bsp engines. I havent even had the air filter off of one of them in 3 years. They are very reliable. And still make almost 10hp out of the box.
gokarttimmy
Pittsburgh,Pa.
Yeah-I always wondered how much power these engines actually make out of the box. I don't seem to be able to find much info on them-most people, it seems, use them as a base for modifying according to their sanctioning body. Mine runs good-my Ken-Bar kart is light and it goes like stink. I also have a 212 Predator with the governor and oil sensor removed-I ought to put it back together with a header and new air cleaner and compare......
Bbqjoe
Banned
Location, Location
I've been looking for that answer for 3 years ! Only thing I can ever find is dyno comparison between the colored clone combos.
It must be one of those secret recipe kinda things.:rolleyes:
Hey! I just paid a wad for a prebuilt BSP!
Cool! How many horses is it?
I don't know.
gokarttimmy
Pittsburgh,Pa.
I paid just over 200 bucks (before shipping) for a BSP engine and billet flywheel...Compare that to a Predator 212 (about 100 bucks), a flywheel (another 100 bucks), average camshaft price (about 50 bucks), billet rod (80 bucks),and then you have to put the thing together.....So far that's approx. 330 dollars. Now, the BSP has a "performance cast connecting rod" and a "hardened crank" as well as a Bsp-3 cam and supposedly modified cast cylinder head. All included. I personally do not have information regarding a comparison between the 212 parts and the BSP parts-and I would suppose the 212 project will have more potential-(plus, it's cool to build a 212) but it's a matter of dollars to horses. For what I'm doing, the BSP is a bargain.
gokarttimmy
Pittsburgh,Pa.
Proper Idle Mixture On RuXing Carb
Got a 196cc BSP clone from ARC Racing with a billet flywheel. I replaced the #36 main jet on my RuXing carb with a stock jet. After running it for about 10 minutes, I removed the Autolite plug and it was still black. I still have a .22 idle jet. Should I adjust the idle mixture on the carb? Dumb question time:Does turning it in (clockwise) make it richer or leaner? Thanks for any info.
