brought a concord today
fowler
Bullsbrook West Aus
ok not the one you are thinking of
a victa concord for $50 and a $10 warehouse gift card
and an Ings edger for $30
both PO claimed they would run great but failed to demonstration it
the edger just had a rotten fuel line
and the victa did eventually get going arfer 1/2 an hour of messing around
the Ings edger has a Tecumseh engine of proberbly 3hp
runs strong but leaks fuel
i was wondering if anyone would know what it is
i need the little elbow that goes from the fuel line into the carb
and an air filter
but the only trace of identification is a piece on the sump with shows signs of grinding
theres nothing on the blower houseing or anywhere else
the Victa is a power torque 2 stroke and when it does run its great, iv never messed around with 2 strokes much but this one fairly screams
it only issue is the revs wont hold
got nothing to do with the controls one minute itll be sitting there at mid revs next minute its going full noise
i suspect its due to the broken primer bulb
im unsure wether its governed or not but if it is then its not working
just by the sound of it i can tell my gsxr 600 engine wont touch it and that red lines at 15'000
it also sounds like its idleing at 4000
needless to say i tested it on a small patch of lawn mowing at what is currently idle and it had a hell of a lot of torque
handles the long grass much better than ride on mower
two great maxchines for a decent price
just a shame people wot look after there stuff a bit better
ak99
Queensland, Australia
Looks like a good score!!
Regarding your questions about the Victa:
Yes they do run a governor, however it's vacuum operated.
There is a cap on the rear of the carb, has a tube going down to the bottom of the crankcase ( difficult to see unless you remove the plastic cowling)
Basically, as air from the flywheel passes over a venturi in the bottom of the crankcase a vacuum is created. This pulls on a diaphragm in the carb and controls the position of the poppet valve inside the carb. ( these carbs have a poppet valve, not a butterfly)
These carbs don't have an idle circuit. When the engine is idling it's actually running on partial choke so you'll never really achieve a smooth idle from it.
When in operation they are designed to be operated with the throttle control in the "Run" position. If this isn't done, over time the result will be a fouled spark plug and blocked muffler.
With the throttle control in the "Run" position, the engine should sit at about 3600 rpm and should hold that speed steadily.
These engines have pretty good low end torque, they don't need to be screaming to get through long grass.
The first thing I would do is grab another primer cap. There is an o ring around it, this should also be replaced. Undo the brass screw in the centre of the cap, just be careful not to lose the needle when you remove the old cap as it and the float will fall out. When you install the new cap, there is a line on the cap that needs to be horizontal ( pretty easy to see)
If that doesn't fix the problem, check to make sure the governor vacuum line is connected and the area around the flywheel is clean. Sometimes they get clogged up with grass.
The final thing to check is the diaphragm in the back of the carb, pop the cap off ( don't lose the spring that pops out) and make sure it isn't split and is sealing all the way around.
By the way, I have diagrams of all this stuff here if you need them.
Hope this helps
Cheers
fowler
Bullsbrook West Aus
cheers
that should keep me outta trouble for a while
should be a simple enough fix
it all looks pretty basic once the cover is off
